keepingbusy
I'm fixing a 1970's modular home for myself, it needs to be re-roofed, and the side of the roof (rake?) overhangs the roof of the attached garage, not leaving enough space for someone can get a roofing nailer in there. I suspect that when it was built, the techniques and materials used for roofing were a little different. Interestingly enough, one of the things left by the original owners was a large painting, more like a colored print of an aerial photo of the house when it was built, and in it one roof simply overhangs the other, and it looks great. Unfortunately, I didn't take a picture of it.
At some point, someone "boxed in" the overhang, I suspect to facilitate re-roofing. The boxes at both ends of this modification show wood rot, and at least the front served as starling's nest, and since I don't see proper flashing between the outer aluminum covering (flashing) going under the current shingles, I suspect that water travels down along the wall between the house and the garage causing problems. Note, on the original plat that I was able to find, it shows only the house and not the garage, but the garage looks to be pretty old too, and ties into the house perfectly as if it were built by the original builder.
Since I'm a practical person, and since I plan on tearing off this "box" along the space below the topmost roof to remove the shingles and inspect the framing, etc., I was thinking of simply shortening the overhang enough to where the shingles over the garage could easily be serviced, replaced, etc. from hereon, perhaps 2"-3".
With all that said, is there a building code that governs how much a rake (I believe that's the term for the top overhang) protrudes or overhangs the side of the house? if so, can someone please tell me where I can find it?
Thanks in advance for any help and I hope everyone is having a safe week!
BTW., the gutters and downspouts have been temporarily fixed, leveling, caulking, and hangers, and the fascia will be replaced with PVC or whatever it is the synthetic stuff is called when the roof is done.
