It's getting hot out there, people.........
480sparky
Silver Member
Heat-Related Dangers
Know What These Terms Mean:
Heat wave: Prolonged period of excessive heat and humidity. The National Weather Service steps up its procedures to alert the public during these periods of excessive heat and humidity.
Heat index: A number in degrees Fahrenheit (F) that tells how hot it really feels when relative humidity is added to the actual air temperature. Exposure to full sunshine can increase the heat index by 15 degrees F.
Heat cramps: Heat cramps are muscular pains and spasms due to heavy exertion. Although heat cramps are the least severe, they are an early signal that the body is having trouble with the heat.
Heat exhaustion: Heat exhaustion typically occurs when people exercise heavily or work in a hot, humid place where body fluids are lost through heavy sweating. Blood flow to the skin increases, causing blood flow to decrease to the vital organs. This results in a form of mild shock. If not treated, the victim may suffer heat stroke.
Heat stroke: Heat stroke is life-threatening. The victim's temperature control system, which produces sweating to cool the body, stops working. The body temperature can rise so high that brain damage and death may result if the body is not cooled quickly.
Sunstroke: Another term for heat stroke.
If a Heat Wave is Predicted or Happening
Slow down. Avoid strenuous activity. If you must do strenuous activity, do it during the coolest part of the day, which is usually in the morning between 4:00 a.m. and 7:00 a.m.
Stay indoors as much as possible. If air conditioning is not available, stay on the lowest floor, out of the sunshine. Try to go to a public building with air conditioning each day for several hours. Remember, electric fans do not cool the air, but they do help sweat evaporate, which cools your body.
Wear lightweight, light-colored clothing. Light colors will reflect away some of the sun's energy.
Drink plenty of water regularly and often. Your body needs water to keep cool.
Drink plenty of fluids even if you do not feel thirsty.
Water is the safest liquid to drink during heat emergencies. Avoid drinks with alcohol or caffeine in them. They can make you feel good briefly, but make the heat's effects on your body worse. This is especially true about beer, which dehydrates the body.
Eat small meals and eat more often. Avoid foods that are high in protein, which increase metabolic heat. Avoid using salt tablets unless directed to do so by a physician.
Signals of Heat Emergencies
Heat exhaustion: Cool, moist, pale, or flushed skin; heavy sweating; headache; nausea or vomiting; dizziness; and exhaustion. Body temperature will be near normal.
Heat stroke: Hot, red skin; changes in consciousness; rapid, weak pulse; and rapid, shallow breathing. Body temperature can be very high-- as high as 105 degrees F. If the person was sweating from heavy work or exercise, skin may be wet; otherwise, it will feel dry.
Treatment of Heat Emergencies
Heat cramps: Get the person to a cooler place and have him or her rest in a comfortable position. Lightly stretch the affected muscle and replenish fluids. Give a half glass of cool water every 15 minutes. Do not give liquids with alcohol or caffeine in them, as they can make conditions worse.
Heat exhaustion: Get the person out of the heat and into a cooler place. Remove or loosen tight clothing and apply cool, wet cloths, such as towels or sheets. If the person is conscious, give cool water to drink. Make sure the person drinks slowly. Give a half glass of cool water every 15 minutes. Do not give liquids that contain alcohol or caffeine. Let the victim rest in a comfortable position, and watch carefully for changes in his or her condition.
Heat stroke: Heat stroke is a life-threatening situation. Help is needed fast. Call 911 or your local emergency number. Move the person to a cooler place. Quickly cool the body. Immerse victim in a cool bath, or wrap wet sheets around the body and fan it. Watch for signals of breathing problems. Keep the person lying down and continue to cool the body any way you can. If the victim refuses water or is vomiting or there are changes in the level of consciousness, do not give anything to eat or drink.
heat exhaustion is marked by heavy sweating, paleness, weakness, diziness, headaches.
heat stroker is marked by absence of sweating, red/flushed skin, high body temp, strange behavior (ok.. with code guys.. ignore this symptom), confusion, disorientation, rapid pulse and hallucinations.
sparky is right.. it's going to be a hot summer... drink water and pay attention to your surroundings.. including other people.
Hallucinations! Well I have them quite often while on inspection. Sometimes I can't believe what I am seeing! It happens in winter also! Are you sure this is a sign of heat stroke or just a good stroke.
Having recently moved from the Southern Nevada desert (Las Vegas) to north-central Kansas (Salina), the heat related issues of summer are quite different, but just as serious. You can't rely nearly as much on the cooling effects of perspiration in a humid climate, as most of you know. The desert allows much more efficient evaporative cooling.
I recently got the dress code approved/changed for field inspectors in Salina... for the first time, they are now allowed to wear shorts! (With nice city polo shirts). I was very surprised when I arrived here that that wasn't already the policy. In Las Vegas, it is standard procedure during summer. Still, the warnings posted above are just as important no matter what you are wearing.
If you haven't gotten your inspectors in short pants (optional, of course), please try to get the policies changed.
"If you haven't gotten your inspectors in short pants (optional, of course), please try to get the policies changed"
We tried that at my last job; but, had trouble in residential areas. The house wives wouldn't leave me alone. I can't help it if I have great legs. :)
On the serious side; lot's of water, protection from sunburn and pace yourself.
Uncle Bob
Uncle Bob said:
"If you haven't gotten your inspectors in short pants (optional, of course), please try to get the policies changed"We tried that at my last job; but, had trouble in residential areas. The house wives wouldn't leave me alone. I can't help it if I have great legs. :)
Uncle Bob
iHEAR YA! These legs cause riots when exposed. they have not seen the light of day since my teens. they are a shade of white that can blind people if exposed:mrgreen:
101 with high humidity is HOT, Fred...
shorts? oh, man.. then I'd have to shave those white things holding my feet up.. :(
The visualization of that made me throw up in my mouth a bit!!!
We can wear shorts if the official weather channel forecast for the county is 95 or higher. Good knee pads often come in handy for me.
