K-12 Fieldhouse Occupancy Classification
RJMCGUIRE
Fort Worth Texas
I am about to start on a K-12 Fieldhouse for a school that has existing buildings; which are all probably Group E.
I'm using the 09 IBC and would think that this fieldhouse could either be A-3 or E.
anythoughts are appreciated.
Thank you,
RM
RJMCGUIRE,
Welcome to the Building Codes Forum!
If I may, ..can you please provide some more basic information, such as:
Can you clarify what you mean by "Field House", ..what is the calculated
occ. load, ..net square footage, etc. Thanks!
Welcome from a fellow dfwer
How did you find us
How many sq ft
Is it stand alone or attached to another building
Field House or Fieldhouse is a common name for indoor sports arenas and stadiums, mostly used for basketball, volleyball, or ice hockey.
A-4 Assembly uses intended for viewing of indoor sporting events and activities
This building will be a detached new building for the school that will house the Girl's and Boy's Locker rooms, a classroom for athletics, coach's offices, training room (i.e. weights and strength training), laundry, and sports equipment storage; plus non-assignable areas like coach's restrooms and lockers, fire riser rm, janitorial and misc. storage.
I was thinking that A-3 or E would be the appropriate occupancy; as there will be no sports viewing activities taking place as in an A-4 occupancy.
the building is programed to be a maximum of 9,595 sq.ft. - 1 story.
i haven't gotten far enough to run occupancy calcs. i would need to get into the program and define each space in order to do so.... i would think.
CDA
i'm a project manager in fort worth and found this forum by searching for an answer to an accessibility question i had. and i'm very glad i found this forum. its a very good source.
Welocome to the Forum RJMCGUIRE!
I would be leaning towards A-3 if there is no viewing........seems to be a good fit.
Here is what we have in CT.......but the others have you on the right track where they say A3 with no spectators....
CHAPTER 3 – USE AND OCCUPANCY CLASSIFICATION
(Amd) 302.2.1 Assembly areas. Accessory assembly areas are not considered separate occupancies if the floor area is equal to or less than 750 square feet. Assembly areas used solely for purposes that are accessory to Group E occupancies are not considered separate occupancies. Accessory religious educational rooms and religious auditoriums with occupant loads of less than 100 are not considered separate occupancies.
Exception: Special amusement buildings as defined in Section 411.2 of this code.
Thanks Everyone.
After breaking down the spaces; this is what chapter 10 is telling me. let me know what you think.
Sq.Ft. Occupancy
Coaches Offices 600 Business 6
Weight Room 1250 Exercise - 50 sq.ft. gross 25
Classroom 1000 Educational - 20 net 50
Girl's Lockers 1600 Lockers- 50 sq.ft. gross 32
Training Room / Laundry 500 Exercise - 50 sq.ft. gross 10
Storage 900 Accessory - 300 gross 3
Boy's Lockers 1600 Lockers- 50 sq.ft. gross 32
Concession 200
Total Net 7650 Total Occupancy 158 (preliminary)
Unassignable Areas
Vestibule 115
Storage 1 64
Coaches R.R. 1 64
Coaches R.R. 2 64
Fire Riser Rm 64
Electrical 96
Janitorial 64
Outdoor R.R. 1 64
Outdoor R.R. 2 64
Total Unassignable 659
Covered Walkway 1 520
Covered Walkway 2 425
Total Non-A/C 945
Total Area Under Roof 9254
If this is the right track. then i'm looking at either nonseparated occupancies or separated occupancies.
303.1.3 Associated with Group E occupancies.
A room or space used for assembly purposes that is associated with a Group E occupancy is not considered a separate occupancy.
