David Henderson
Replacing cabinets, counter tops, and flooring, no plumbing, or electrical. Do you require the 4' spacing on the GFCI's then?What say you all?
Replacement of plumbing and electrical were to be included.David Henderson said:reconfiguration of cabinets,and counter tops. Francis don't know if you were talking about new devices or wiring, new plumbing under the sink... no
I would require GFCI if they are upgrading the electrical in a kitchen. That said, replacing a sink, countertop, or cabinets, no. I do however suggest that they add GFCI.Francis Vineyard said:Replacement of plumbing and electrical were to be included.
Dennis said:I agree. If the counters are being replaced nd the configuration is the same then I see no way that you can be forced to do any electrical work on it. BTW some areas around here have made home owner get permits for changing their cabinets. I guess if you uninstall a sink and add a new one it must be inspected but I don't know why they made them get a building permit.
True and there are answers if they were to get a permit were it not required.gfretwell said:If they are adding, extending or modifying the electrical, the GFCI and 210.52(B) is more than a suggestion. The original question was cabinetry only.
