Yikes
2016 California Electrical Code section 210.52 requires "Receptacles must be installed so that no point along the counter wall space is more than 24 inches (2 feet), measured horizontally, from a receptacle outlet. Exception: receptacle outlets are not required on a wall directly behind a range, counter-mounted cooking unit or sink".
I have a question regarding measurement, and it relates both to ADA and to the electrical code.
Picture a typical kitchen cabinet, 24" deep with a 25" deep countertop, but this is an ADA compliant unit.
ADA has a maximum reach range of 24" when a wheelchair is parallel to the cabinets. ADA requires that all outlets be within the 24" reach for the user
- The inside corner is inaccessible and is 25" deep. If I put the outlets within reach, they are further than 25" from the back corner, in violation of electrical code.
- If I put the outlet on the front of the cabinets, this too violates the distance rule of the electrical code, because I measure to the back wall.
- If I put an extension box on the outlets, this is still further than 24" away from the inside corner.
