Our home has 4 exterior doors. Two meet the requirements for Egress door with the 36" deep landing. All doors open in. In the rear of the house we used to have a wood deck at the same level as the interior of the house. It has been removed and we need to create steps down to the ground outside for those two doors. The interior floor is about 2 ft off the ground so each set of stairs requires 4 risers 6 inch each to get to the ground. The yard is small so we were hoping to make the landing 18" in direction of travel.
Our landscape architect went to LADBS to get clarification of the code. We were told the landings had to be 36" but that applied to the one required egress door and the others the stairs could start at the door with no landing as long as the door did not open over the stairs. However, the landscape architect did not feel confident in the answer because the individual said the code was not clear.
So I went back to LADBS to get clarification and copy of the code and was told again stairs could begin at door. I asked for a copy of the code.See below. But when I read it it seems to say that 36" in direction of travel is required.
We don't meet the exception of 2 or fewer risers as we have 4. But some how does "Floor elevations for other exterior doors. Doors
other than the required egress door shall be provided with landings or floors not more than 7 3/4 inches below the top of the threshold." apply that I'm not getting?
Any help greatly appreciated.
2011 City of LA Residential Code
311.3 Floors and Landings at exterior doors. There shall be a landing or floor on each side of each exterior door....Every landing shall have a minimum dimension of 36 inches measured in the direction of travel......
R311.3.2 Floor elevations for other exterior doors. Doors
Exception:A landing is not required where a stairway of
two or fewer risers is located on the exterior side of the
door, provided the door does not swing over the stairway.
