Large walk-in cooler storing flammable liquids
JCD3
NC
Really got into a complicated issue with a new 40,000 sf warehouse storing IB & IC flammable liquids and exceeds MAQ's so have a part of the building classified H-3. Initially it was thought that no flammable products would be in this huge 10,000 sf cooler but apparently there will be plenty in there so now it's a part of the H use. We've worked most of the code issues out for this however the last thing is ventilation. There are min ventilation requirements but apparently there is no exemption for coolers. How is it possible then? Emergency ventilation with alarm? The liquids do not produce any hazardous fumes or gases but, again, no exemptions found.. or at least none I could see.
I was bored so I went on the hunt for ya. The rabbit hole took me to the ifc. I’m not versed well enough in hazard classifications, but I found something in the ifc stating natural ventilation that is deemed acceptable? By whom I do not know… and like I said, I’m a newbie in the insp world… so I dunno if that even helps. It killed the last 30 min of my shift though. Better than more studying! Good luck
Thanks, I do appreciate it. I've done the same as well with this stuff.. blame the ADD
