Question relates to application of Section 707 Shafts as is affected by Section 706.5 continuity of firebarriers.
Issue is a Laundry Chute, and the detail for the chute support.
The shop indicates the supports to be attached to the floor passing through the shaft. This would assume that at each floor, the fire barrier discontinutes/continues at each floor deck.
Construciton is wood, Type Vb and the floor assembly is 1 hour. with a topping.
I can see both answers. 1) being the chute shall be a continuous void without the floor passing, etc. And 2) the construction need not be this and the benefit of creating a floor to floor fire blocking via continuing the deck through.
Both scenarios, the floor structure would not be exposed within the chase.
