Papio Bldg Dept
ADASAD 604.7 Dispensers does not appear to address any other dispensers. I am assuming since it only specifically addresses toilet paper dispensers, that this does not cover other dispensers or sanitary receptacles mounted underneath the grab bar between the toilet paper dispenser range and the back wall. Does anyone have any insight into this before I reach out to the access-board?
604.7 Dispensers. Toilet paper dispensers shall comply with 309.4 and shall be 7 inches (180 mm) minimum and 9 inches (230 mm) maximum in front of the water closet measured to the centerline of the dispenser. The outlet of the dispenser shall be 15 inches (380 mm) minimum and 48 inches (1220 mm) maximum above the finish floor and shall not be located behind grab bars. Dispensers shall not be of a type that controls delivery or that does not allow continuous paper flow.
Advisory 604.7 Dispensers. If toilet paper dispensers are installed above the side wall grab bar, the outlet of the toilet paper dispenser must be 48 inches (1220 mm) maximum above the finish floor and the top of the gripping surface of the grab bar must be 33 inches (840 mm) minimum and 36 inches (915 mm) maximum above the finish floor.
Also, does anyone know why the vertical grab bars went away? Are they still a good idea from a design standpoint?
