tbz
Hello All,
Project is in Wisconsin and the requirements surrounding a spiral stair as the only accesses to a "LOFT" 10ft x 12ft (120sqft)
My Client, the Fabricator of the spiral stair is currently planning to fabricate a 4'-3" diameter spiral for access to this loft.
However the end user, ie: homeowner , has informed the my client the fabricator, and I quote:
"Somewhere along the line, they found info that their loft area of 10x12 does not need a spiral that meets code."
The Homeowner wants a smaller diameter spiral...
The only thing I can find specific to this in the WI Code, is the following:
"SPS 321.03 Exits. Exits, doors and hallways shall be constructed as specified in this section.
(4) Exits from lofts.
(a) At least one stairway exit shall be provided, to the floor below, for a loft exceeding 400 square feet in area.
(b) At least one stairway or ladder exit shall be provided to the floor below for a loft, 400 square feet or less, in area."
And as thus, my interpretation is that the home owner has the option to either have a stair, spiral stair or ladder as access, but nothing says the stair, spiral stair or ladder does not have to meet code compliance.
Correct me if I am wrong please or at least confirm I am reading the requirement correctly that (b) applies which requires one or the other being under 400 sqft.
Thank you
Thank you
