Lunch room on Mezzanine
Mech
Eastern PA
2009 IBC
Does the phrase "dining areas" include lunch rooms or was the intention to mean restaurants?
Section 1108.2 . . . Dining areas shall comply with Section 1108.2.9.
Section 1108.2.9 In dining areas, the total floor area allotted for seating and tables shall be accessible.
1. In buildings or facilities not required to provide an accessible route between levels, an accessible route to a mezzanine seating area is not required, provided that the mezzanine contains less than 25 percent of the total area and the same services are provided in the accessible area.
Existing building w/ an existing mezzanine where the owner wants to put a lunch room. The mezzanine exceeds the 25% maximum mentioned in 1108.2.9 Dining Areas. If I put a lunch room on the mezzanine, it appears I need an accessible route due to the 25% rule, even though there is an existing lunchroom on the main floor.
Employee common use areas (e.g., locker rooms, break rooms, cafeterias, toilet rooms, corridors to exits, and other common use spaces) shall be accessible per ADAAG 4.1.3(1) http://www.ada.gov/regs2010/titleIII_2010/reg3_2010_appendix_b.htm
But you are not empowered to enforce the ADA
ADA
Employee Work Area. All or any portion of a space used only by employees and used only for work. Corridors, toilet rooms, kitchenettes and break rooms are not employee work areas.
Common Use. Interior or exterior circulation paths, rooms, spaces, or elements that are not for public use and are made available for the shared use of two or more people.
IBC
EMPLOYEE WORK AREA. All or any portion of a space used only by employees and only for work. Corridors, toilet rooms, kitchenettes and break rooms are not employee work areas.
COMMON USE. Interior or exterior circulation paths, rooms, spaces or elements that are not for public use and are made available for the shared use of two or more people
