Mandatory Electrical Conduit in New Residential Construction
Forum Coordinator
Somewhere Too Hot & Humid
What if the National Electrical Code (NEC) mandated that all new residential constructions include a minimum of 60% conduit wiring instead of non-metallic sheathed cable? Would this significantly enhance safety and flexibility for future upgrades, or would it be an excessive and costly requirement?"
  1. Safety and Durability: Conduit wiring is generally considered more durable and safer against physical damage and fire hazards compared to non-metallic sheathed cable. This aspect can lead to discussions about the balance between safety and cost.
  2. Cost and Labor Implications: The significant increase in material and labor costs associated with conduit wiring compared to non-metallic sheathed cable could be a major point of debate, especially in terms of its impact on the overall cost of housing.
  3. Future-proofing Homes: While conduit wiring offers easier access for future upgrades or repairs, there's a debate on whether such a level of future-proofing is necessary for all residential constructions.
  4. Industry Adaptation: How such a change would affect electricians, builders, and the construction industry in general, considering the different skills and time required for installing conduit wiring.
Welcome to Chicago.bSuburb actually. I renovated a house there and it was all conduit, as required, replacing knob and tube. I have heard the suburb has since started to allow no metalic.
I see the future additions as not valid. Future renovations, conduit would be n the way more than a help.
Is the only choice offered here between conduit and Romex? Just last week I overheard our electrical inspector saying that MC is now cheaper than Romex. I do any new wiring in my house with MC. (Mice chew on Romex.)
I don't see the correlation between unions and installing conduits.
It is the union electricians that keep (or kept - not sure if changed recently) non-metallic out of Chicago codes. Simply assured more work for electricians. Same for Chicago's 3 circuits max per conduit, regardless of size. Most of the electrical inspectors are or were union members.
Not surprising for a jurisdiction that sells ads to manufacturers and contractors in their code book.
That may be true for materials etc. but I wonder what the cost differential is if you factor in labor. Labor to install conduit and pull wires has to be significantly higher than running Romex!
