Table 404.2.3.1 has maneuvering clearances for doors without latches and closers and then adds more maneuvering space when latches and/or closers are added to doors.Maneuvering clearances are required for doors which have a latch AND a closer. I'm not sure I've ever seen an interior door with a closer in a residence. The only case I can think of might be a secondary exit to a stair in an apartment.
I only have 2006 which we are using in PAAgreed, the continuous unobstructed path is required. The current required code is 2009. Are you quoting 2006? The code (2009) says that the primary entrance door needs to comply to section 404 for the Type B. That is to say while Type A requires all doors to comply with section 404, Type B does not. Do you read it the same?
