Woodrow
Has anyone had a customer that wants to change a manufactured home classification from a dwelling to a storage use?
House.Acessory to the house storage or commercial storage?
So its a shed....I wouldn't worry about it...Unless they want to use it as a garage...House.
Here is a summary of the differences between mobile homes, manufactured homes, and modular homes:Are all manufactured homes mobile homes? What about modulars?
Mobile Homes
Manufactured Homes
- Built before June 15, 1976
- Also known as trailer homes or manufactured homes
- Constructed on a steel chassis with wheels, allowing for easy relocation
- Typically smaller in size, with a maximum width of 8 feet 6 inches and a maximum length of 40 feet
- Not designed to be permanently attached to a foundation
- Often associated with temporary or transitional housing
Modular Homes
- Built after June 15, 1976
- Constructed on a permanent chassis, but not designed to be relocated
- Can be built on a variety of foundations, including a permanent foundation, pier and beam, or a crawl space
- Can range in size from small to large, with no maximum width or length limits
- Held to federal building codes set by the Department of Housing and Urban Development (HUD)
- Often referred to as “mobile homes” by some manufacturers, but this term is no longer officially used
Key differences between manufactured and modular homes:
- Built in a factory, but designed to be permanently attached to a foundation
- Constructed on a permanent foundation, similar to traditional site-built homes
- Held to local and state building codes, rather than federal codes
- Often difficult to distinguish from traditional site-built homes
- Can be customized to meet local building codes and design preferences
It’s worth noting that the terms “mobile home” and “manufactured home” are often used interchangeably, but technically, “mobile home” refers to homes built before 1976, while “manufactured home” refers to homes built after 1976.
- Manufactured homes are built to federal codes and are designed to be moved, while modular homes are built to local and state codes and are designed to be permanent.
- Manufactured homes are typically smaller and more affordable, while modular homes can be larger and more customized.
- Manufactured homes are often associated with temporary or transitional housing, while modular homes are designed to be permanent residences.
Not really...What's the source of these definitions? It's not the IBC or IRC. The ICC definition could apply to either a "trailer" home or a modular.
Check your state laws. I bet the definitions are very close.What's the source of these definitions?
