Applicant has an existing masonry fireplace and chimney in an existing single story house. The owners are proposing a second floor addition that will be built within 10’ of the existing chimney. The owners will be installing a gas fired insert within the existing fireplace opening. Would you require the chimney to be raised so that it meets the IRC, IBC code clearances for a masonry chimney? Or provide the clearances required by the Gas fired insert manufacturer which are less.
