I have a building that is an existing three story apartment building. There is a means of egress that was added at some point off the second floor out the back. It was most likely a window which was made in to a door with stairs going down. From the two apartments on the third floor they build steps from the window to the building behind it. The building that behind the apartment building had some new construction and caused the steps that were off the second floor of the apartment building needing modification. The issue is that there is limited space between the apartment building and the building behind it. Maybe 5 feet. What code would you reference for the replacement of the steps when there is limited access to begin with? They want the steps to be put back but there is difficulty meeting current code. Any thoughts would be appreciated.
