2012 Virginia Residential Code (basically same as 2012 IRC)
Here's the simplified version of my question: Does the code require a minimum dimension for the depth of a landing on the exterior side of a "man"-door for a garage?
The code talks about minimum landing depths within the section on egress doors, but I don't think a door out of a garage is considered an egress door, right?
Here's more detail:
I'm designing a house with a detached garage (although it's connected to the house with a porte cochere so the owners can walk out the side door of the garage and over to house while under cover of roof.) For the exterior door out the side of the garage I need to go down three risers to get to grade. I'd like to have one riser right at the threshold of the door, then a 2'-6" deep landing, and then two more risers. Is this acceptable? Or does the code require a 3'-0" deep landing?
Here's more detail:
