E87
Hello everyone, I have another question I was hoping to get some discussion about. Here's my situation:
I have a mixed use occupancy consisting of 7500 SF of F-1, and 4100 SF of S-1. Construction type is 5B. So when looking at the allowable areas for each occupancy, F-1 is allowed 8500 SF, and the S-1 is allowed 9000 SF. So each occupancy, when looking at separately, are under their allowable square footages. And after looking at Table 508.4 (Fire separations required between occupancies), I found that there is no separation requirement between S and F occupancies.
So my question is wether or not I am correct in saying that I do not need to have a fire wall separation between the two occupancies. Maybe I am just confusing myself but when you look at the building as a whole, the total SF of the building is 11,600 SF, which is over the allowable area of the two occupancies.
I understand that when you are over your allowable fire areas in a single use facility, you can divide the facility into several "separate buildings" by using fire walls to get each piece under the allowable SF. I am getting confused with this mixed occupancy facility.
Any thoughts, suggestions are much apprecitated!
