Mortar from a caulking gun?
MikeC
NW Pennsylvania
I was speechless. Some sort of caulking used as mortar. I didn't even know what it violated. The best I could come up with on the spot was IPMC 102.5Yes, I stuck my knife in it. I figured if it was properly done, I shouldn't be able to do any damage with a knife. Just another slumlord adding lipstick to a pig.
/monthly_2013_11/ResizedImage_1384982400704.jpg.f936ff31ab889ebaf11bb27774722bd3.jpg
/monthly_2013_11/2013-11-20_15-32-53_852.jpg.d97aec2613429c1c6a43a3bc4be2d176.jpg
Several companies produce a latex sanded compound for pointing up motor joints.
I used grey latex caulk to repair non-structural brick mortar joints a couple of times... I also googled 'mortar in a caulk gun' and found that most listed were for latex based pointing repair, but... one manufacturer does make a caulk gun like device that can deliver actual mortar for bedding. I didn't take the time to read the details, but I would imagine that it is site mixed mortar that is applied via the device, as mortar will hydrate even in a sealed container (lacking some alternative mixture that would delay the process).
If it doesn't comply with ASTM C 270, and if its not type M or S it can't be used for structural in foundation walls. IRC 607.1
