OhioAviator
Hello all,
I have a situation that I'm just not sure if it meets NEC and OSHA requirements. The situation is this...
We have an 18" aluminum cable ladder with 6" side rails and 9" rung spacing. This cable ladder is fastened to 5/8" Unistrut, which itself is fastened to a concrete floor. Installed in the cable ladder are several power cables, a divider, and several multiconductor NM cables. About 3 feet away from the end of the cable ladder, the electrical contractor dipped the multiconductor NM control cables down underneath the cable ladder and continued the run of control cables along the concrete floor (running underneath the cable ladder) where they terminate via box connectors into a control cabinet.
I wish I could paste an image from my computer hard drive of what I'm describing, but apparently, I'm not permitted to do that.
Basically, my question is... are NM multiconductor control cables permitted to lay on a concrete floor even though it's protected by a cable ladder immediately above?
Thanks in advance!
Thanks in advance!
