retire09 said:
.What is the violation and concern?
Fire officials warn against using multi-plug cords and adapters
http://www.beloitdailynews.com/news/fire-officials-warn-against-using-multi-plug-cords-and-adapters/article_0041b460-4900-11e1-9bb9-0019bb2963f4.html
Posted: Friday, January 27, 2012 4:00 pm | Updated: 10:54 am, Mon Jan 30, 2012.
Hillary Gavan | 0 comments
Town of Beloit Fire Department Capt. Rich Tippelt is urging residents to use caution with multi-plug extension cords and adapters. The best policy, he said, is to avoid buying the items and to use power strips with surge protectors instead.
In the fire of a mobile home on Monday afternoon, a woman had plugged her space heater into a multi-plug adapter. Tippelt said there is a multi-plug adapter on the market with two prongs on the back, and it's designed to be placed over an two-prong outlet and screwed into the outlet. It converts a two-plug outlet to a six plug outlet.
Because the devices can accept limited amperage, Tippelt advised avoiding them, especially when using them to plug in microwaves, space heaters, computers or any items that draw large amperage. He said more traditional power strips have built-in circuit breakers, and are the better choice.
The other danger is multi-plug extension cords. It's also important not to cover any extension cord with a rug. Legally, extension cords are permitted for temporary use only, and not with space heaters, microwaves or other devices emitting high amperage. In commercial construction, Tippelt said holiday lights are only allowed 30 days before and after a holiday for decoration or light purposes.
There are prohibitions against use of multi-plug extension cords and adapters in the National Fire Protection Association codes for commercial construction. Although the fire department doesn't typically inspect residences, Tippelt said if a fire occurs as a result of a device, residents could be subject to a fine.
The fire department hasn't issued any of the fines yet, opting to educate the public instead. Tippelt said he was heading out to the mobile home fire site on Tuesday to educate the owner about not using multi-plug devices and implementing smoke detectors. Smoke detectors are required on every floor of a residence. In the case of a long ranch-style home or mobile home, Tippelt advises using a minimum of two smoke detectors.
Multiplug adapter causes Laguna Woods condo fire
http://www.ocregister.com/articles/concialdi-627421-fire-damage.html
LAGUNA WOODS – An overloaded electric outlet has been determined as the cause of a blaze that destroyed a condominium kitchen and caused about $275,000 in damage Saturday night, authorities said.
The fire, which ripped through an upstairs unit of a residential building in the 3300 block of Monte Hermoso, began at about 8:30 p.m. and took 20 firefighters about 20 minutes to extinguish, Orange County Fire Authority Capt. Steve Concialdi said.
Structural damage was estimated at $200,000. About $75,000 of the condominium’s contents were also damaged, Concialdi said.
One resident was displaced by the fire but was uninjured, Concialdi said.
Concialdi said unplugging small kitchen appliances when not in use and avoiding overloading electrical outlets is vital in preventing fires
