'Murrican code question from a Canuck
Inspector Gadget
New Brunswick
I live quite close to the Excited States. On Saturday, I had dinner at a bar/restaurant in Maine. Nice day, went on the covered porch/deck for dinner. Saw this - which would fail in Canada.
Would y'all accept this? The spacers on the lintel are 24" apart. Canadian codes limit spacers to 18". Just curious.
Not sure where you were in Maine, but not a lot of enforcement in rural Maine....There was talk of a bill only having a residential code in Towns over 50,000 people which is like 4....That likely wouldn't pass inspection here....For a few reasons....
We don't do split beams here without engineering, if you want a double beam it's got to be laminated together.
In Canada, this would be an A2 assembly occupancy (bar/restaurant), so everything would require engineering by strict application.
Otherwise, I would be able (esp with a 8' total rafter span, so a 4' input) to consider the two elements as a two-ply lintel, as long as the filler pieces were no more than 18" apart *and* the two 2x10 elements could handle the snowload.
