steveray
Medical office renovation, new plumbing, existing wall, drywall removed on only one side.....New pipe is within 1.5" of both sides. Who makes them nail plate both sides?
You may have a bigger problem then nail plates depending on the size of the studsNew pipe is within 1.5" of both sides. Who makes them nail plate both sides?
As long as the metal guard inside the hole does not make contact with the copper LP pipe. Do they make such a protector is your invention, subject to ICC ES reports? :0steveray said:Has anyone thought of putting the nailplate inside the round hole?...I never said anything about drywall removal.....
Will you also require nail plates at 36" a.f.f. (or 32", or 42", or 48") for chair rail? Better be safe.Francis Vineyard said:As steveray presumed helps protect from future shelves, racks, cabinets, chair railing, wall mirrors, pictures, wall ornaments, and other assorted alterations..
Perhaps I misunderstoodmjesse said:Will you also require nail plates at 36" a.f.f. (or 32", or 42", or 48") for chair rail? Better be safe.How about the entire height of the wall, you never know where Mrs. Homeowner is gonna want to poke holes.
Open side of wall - top plate, bottom plate - done. Unless you own stock in Simpson or Teco, there's no reason to start requiring nail guards for every possibility you can imagine. Especially for a finished wall.
mjesse said:Not me.In my opinion, the plates are mostly there to keep the drywaller's screws out of the pipe. Drywall is done already...no plate needed
...or I'm just crabby today. Is it 4:30 yet?Francis Vineyard said:Perhaps I misunderstood
You've got to run a 1/4" drill bit through it first:devilsteveray said:I've tried to put an EZ anchor through a pipe, it's not that easy.....
