Yes, I agree. Nice!300.11(C)(2) Cannot use a raceway for support of class 2 conductors unless solely for the purpose of connection to the same control circuits of the wires in the conduit.
Sure, I'm not aware of any limits on wiring methods that go through a hole drilled into concrete after the fact. Which I infer we have here, given the spalling of the white finish.is the flex conduit allowed to go through the foundation?
Is this an unrelated question? 600.5?Name a section in the code where an outlet is required in every commercial building and each commercial occupancy that is required to have a minimum 20 Amp branch circuit that does not supply any other load. This outlet does not need to have a receptacle, be used or connect to anything at all, and can just have a blank cover over it.
Takes a lot of nerve to do something like this!!! It’s stuff like this that keeps inspectors up at night.One of the low voltage contractors did this on this brand new construction.
Garage bay for fire stationTakes a lot of nerve to do something like this!!! It’s stuff like this that keeps inspectors up at night.
Is that a wet location or just damp?
YesIs this an unrelated question? 600.5?
