tbz
Hello looking for comments on the proposed wording that is currently in front of the NC Building Code Council for the building code which has a meeting next week. The 2" sphere requirement has been in their code since 2009, but of concern to me is the bold under lined area trying to pull loads in to chapter 10 were they dont belong, not to mention the wrong wording for the load requirement.
Please let me know what you think and if you are from NC, what can you tell me about this since they don't seem to publish and reason statements on the proposed modification from model code.
1015.4 Opening limitations. Required guards shall not have openings that allow passage of a sphere 4 inches (102 mm) in diameter from the walking surface to the required guard height. The sphere shall not pass through the opening with a minimum of 50 psf applied horizontally to the sphere from the direction of the walking surface that is being protected. A bottom rail or curb shall be provided that will reject the passage of a 2-inch-diameter (51mm) sphere.
