Francis Vineyard
"There are a number of points to consider before replacing non-grounding receptacles. One point is that the Code is non-retroactive, which begs the question of whether 250.114 applies at all in the case of receptacle replacements where the installation is not new.
What if the manufacturer’s instructions state that the equipment must be plugged into a receptacle with an equipment ground? Section 110.3(B) mandates that the instructions included in the listing and labeling of the equipment be followed. Therefore, if the listing of an appliance includes instructions that state it must be plugged into a grounded receptacle, then simply replacing a non-grounding type receptacle with a GFCI-protected grounding type receptacle is not compliant with 110.3(B).
Finally, the 2011 NEC revised receptacle replacement requirements for arc-fault circuit-interrupter (ACFI’s). If a branch circuit in a new installation required AFCI protection then a replacement in similar branch circuit in an existing installation beginning on January 1, 2014 is required to provide AFCI protection. This is consistent with GFCI receptacle replacements which require GFCI-protected receptacles where replacements are made at receptacle outlets that are otherwise required by the NEC to be protected for a new installation."
2011 NEC Revisions for Receptacle Replacement and 2014 Requirement
Francis
Francis
