tbz
Silver Member
Not sure where to post this question, but I am going to do it here and if it needs to be moved, I will defer to the powers that be.
Have a post WW2 cape cod, the left side of the home has aluminum siding on the "A" peak from the 70's covering old clap board siding that has paint on it.
This side of the home had an aluminum awning that during the big snow push this winter came down pulling 4 sections of siding loose mid span and the bottom pc half off.
We did not test for lead paint, (a) because we are not that type of contractor and (b) not certified.
We are going to be installing a new metal awning for the client and they have requested we fix the siding.
I am pretty sure the paint behind the siding is lead based because of the town and all the RRP contractors you see doing painting projects.
Here lies my question, since this is resetting nails and replacing 1 section of siding am I out of place just fixing it or is this a bigger issue than that?
I am only asking here because of the recent post about Lowes.
Thank you for any input.
