TimNY
Can anybody tell me what this Zurn device is with the 3/4" nipple sticking up out of it:
Thanks,
Tim
Thanks,
Tim
The use of a flow control device (Z1108), furnished with allgrease interceptors, is an important factor in the operation of
the interceptor. The flow control device should be installed in
the waste line upstream of the grease interceptor. It should be
placed beyond the last connection from the fixture(s) and as
close as possible to the underside of the lowest fixture. When
two or more sinks or fixtures are combined and served by one
interceptor, a single flow control fitting can be used.
The flow control device must be properly vented to permit air
to mix with the fluid entering the interceptor. Air facilitates
separation and, more importantly, is necessary to maintain
the proper pressure, thus, the proper operating level within
the separation chamber.
Air intake for the flow control device may terminate under the
sink drain board, as high as possible, to prevent overflow or
terminate in a return bend at the same height outside of the
building. When a fixture is individually trapped and backvented,
air intake may intersect the vent stack. All installation
recommendations are subject to approval of code authority.
Any time Tim, any time.TimNY said:I'm having trouble finding specs for it. ie how high is the relief pipe supposed to be.. tried googling for all sorts of zurn [backwater, atmospheric, etc] but can't find this. I haven't seen one before.Thanks for the help ICE,
Tim
Why not? They are becoming increasing common down here.TimNY said:we don't normally allow indoor grease traps
The people who service the indoor traps aren't typically as hygenic asdesired........Here, the servicers tend to spill grease wastes and not clean"Why not?........They are becoming increasing common down here."
