Need some help here.
crothemi
Where I work we have a data center with a Preaction sprinkler/fire system installed in it.
The sprinkler acpect is tested quarterly.
My question is with the EPO.
Does the EPO function as an output of the fire alarm system have to be tested annualy?
All the people here with pocket protectors and TI-35's are up in arms about me wanting to shutdown their servers.
If anyone knows what chapter and verse of NFPA I should look in for help please let me know.
Look in NFPA 25 and 72 for testing "requirements". It is possible to test parts of the EPO without actually dumping the power.
Testing EPO's can be done depending on how the EPO is configured.
For the Geeks, the best way to conduct a full test is when you plan an outage, even the Geeks need to have an outage once in a while for other issues.
If you do not test it then you do not know if it will work , and if it burns up their system what are the it guys going to do??
But there are other things tied into a fire alarm system that are not full function tested
Like clean agent systems
Also sounds like an added feature that is not required
What does it take to trip the epo?? Every time the fire alarm goes off or when the clean agent dumps, or????
