Architect1281
Had a wise designer today tell me that due to design provided space in this code section that they would not need to provide R-38 per zone 5 but could use R-30
N1102.2.2 Ceilings without attic spaces.
Where Section N1102.1 would require insulation levels above R-30 and the design of the roof/ceiling assembly does not allow sufficient
space for the required insulation, the minimum required insulation for such roof/ceiling assemblies shall be R-30.
This reduction of insulation from the requirements of Section 402.1.1shall be limited to 500 square feet (46 m2) of ceiling area. This reduction shall not apply to the U-factor
alternative approach in Section N1102.1.2 and the Total UA alternative in Section N1102.1.3
Designer provided a 2x10 sloped ceiling / cathedral design and said the space was inadequate to put in the 123" R-38 fiberglass batt.
I told them that the space designed was sufficient to incorporate the required R-38 insulation and they just chose the WRONG INSULATION material.
Install 2# closed cell poly expanding foam which in that space and it would be near R-50 so put in enough to attain R-38; says I
Agree or disagree? but the space seem to be of sufficient space to comply? No Es Verdad?
COMPLIANCE IS THE ALTERNATIVE............
