T
Truck3capt
Guest
Our jurisdiction has been working to try to get all of our existing buildings that qualify as high-rise structures into compliance with the state minimum fire code. (NFPA 101-2000) So they've been asked to sprinkler the building or provide an engineered life safety system analysis of the structure in accordance with the special provisions language in NFPA 101 for existing high rise buildings ( 39.4.2 in this instance, existing B use)
We've adopted the 2012 I-Codes in our jurisdiction so the decision was made to allow the 3412 Compliance Alternatives section in the 2012 IBC to "score" the building and comply with the alternative engineered life safety system analysis portion. One of the evaluations submitted claimed points for a functioning standpipe. Our office requested current ITM documentation. The electric fire pump supplying the system failed and was so old parts were unavailable to repair it. It's being replaced.
The existing pump room doesn't appear to be compliant with all of the requirements of NFPA 20-2010 which would be the appropriate referenced standard for the 2012 IBC.
If the pump is replaced does the rest of the pump room have to be in compliance with the requirements of NFPA 20 in order for the building owner to claim the 6 points for the standpipe system?
