LGreene
I need some help from fire alarm experts on a door-related question. I'm sorry for the long and detailed post - bear with me.
In the editions of NFPA 72 prior to the 2010, it wasn't clear that doors with access control had to unlock in the direction of egress upon initiation of the fire alarm. The code just said that the doors had to unlock, which some AHJs were interpreting to mean that any door with a card reader had to be completely unlocked upon fire alarm.
The 2010 edition clarifies the requirement:
"21.9.1 Any device or system intended to electrically lock a required means of egress door in the direction of egress shall be connected to the fire alarm system serving the protected premises.
21.9.2* Electrically locked doors in a required means of egress shall unlock in the direction of egress as prescribed by other laws, codes, and governing standards."
This requirement would typically apply to doors with electromagnetic locks (access-controlled egress doors) and delayed egress locks (special locking arrangements). One of the gray areas surrounding these two types of locks is whether battery back-up or another type of back-up power can be used to keep the doors locked during a power failure. The IBC says that these types of locks must "unlock upon loss of power controlling the lock or lock mechanism."
While I was researching the NFPA 72 requirements, I was reading the NFPA 72 Report on Proposals for the 2002 edition regarding 6.15.7.3 which refers to fire alarm systems that operate on battery backup.
"SUBSTANTIATION: This proposal is based on the work of a pre-ROP task group of the TC of Protected Premises Fire Alarm Systems. The changes will not allow batteries to be used to lock exit doors when the secondary power supply for the fire alarm system is provided exclusively by batteries. Secondary power supplies that utilize generators may opt to continue to keep the doors in the locked position. This change reflects the change in the permissible secondary power supplies from the previous edition."
This is the 2010 language (it moved to a different section):
"21.9.3* For all means of egress doors connected in accordance with 21.9.1, and where batteries are used in accordance with 10.5.6.1.1(1) as the secondary power supply, the batteries shall not be utilized to maintain these doors in the locked condition, unless the fire alarm control unit is arranged with circuitry and sufficient secondary power to ensure the exits will unlock within 10 minutes of loss of primary power."
And finally, here are is my question:
I interpret all of this to mean that a mag-lock or delayed egress lock can not have battery back-up in the lock power supply. If the fire alarm runs on battery back-up, the lock can't stay locked for more than 10 minutes. If the fire alarm runs on a back-up generator, the lock could also run on the back-up generator and function normally. Agree? Disagree? Other thoughts?
