RLGA
I'm interested in finding out how other jurisdictions handle the requirement for NFRC 100 certification for fenestration per the IECC.
In the 2012 IECC, Section C303.1.3 requires that U-factors of fenestration products be determined in accordance with NFRC 100 by an accredited, independent laboratory and certified and labeled by the manufacturer. If products are not certified and labeled, then the default values in Tables C303.1.3(1) and (2) must be used.
NFRC 100 certification is fine for unit assemblies (e.g. a complete factory-fabricated and factory-glazed unit), but the problem with the requirement above is that field-fabricated systems, such as curtain walls and storefronts, cannot be tested per NFRC 100, because each installation is unique and must be analyzed using the Component Modeling Approach (CMA) by NFRC. The IECC does not recognize CMA specifically, so I'm asking the questions:
- Does your jurisdiction accept CMA as an alternative to NFRC 100 certification?
- Do they even care or ask about NFRC 100 certification?
