NIST Surfside Collapse Update September 2025
The National Institute of Standards and Technology (NIST) continues its investigation into the 2021 partial collapse of Champlain Towers South in Surfside, Florida. Recent findings reinforce earlier conclusions that the failure began in the pool deck rather than in the residential tower.
NIST analyzed photos, maintenance records, and eyewitness accounts, which showed cracks in the first-floor slab, particularly concentrated in the street-level parking and pool deck, years before the collapse. Investigators highlighted visible signs of distress in the weeks prior, including a sliding door that came off its frame, planter wall cracks, a jammed gate, and worsening water leaks from the garage ceiling. Evidence shows the pool deck and parking area began collapsing at least seven minutes before the tower itself.
Ongoing computer simulations and large-scale structural testing point to failure likely starting at a slab-column connection in the pool deck, with contributing factors including steel corrosion, concrete shrinkage, and improperly built construction joints.
NIST expects to complete technical work by the end of 2025 and issue a summary report and six technical reports. The team is working with stakeholders in design, construction, inspection, and maintenance to ensure the findings translate into stronger safety practices for both new and existing buildings.
The next detailed public update is scheduled for spring 2026.
You can find the information here: https://www.nist.gov/news-events/ne...investigation-nears-completion-technical-work
If the structural deformation was enough to dislodge a sliding door, that should have been a canary in the coal mine.
There's an excellent set of commentaries on YouTube from an engineer who has really delved into some of the flags - "Building Integrity" is the channel handle. I watched a crapton of the videos, and the forensic data-gathering by the guy is exceptional.
There were a lot - a lot - of warning signs. And, by the scan of it, many chances to realize something was amiss.
Building users are not that trained or educated. The people that relied on canaries in coal mines (my father did nearly 100 years ago) knew what to look for.
I hear you. My wife drove a car home after she punctured the oil pan. I heard the car from several blocks away. I knew it was her when the building shuddered as she always rubbed a tube steel post holding up our apartment. (passenger side door did not open) I Mentioned that there is something wrong with a car that sounds like a tornado of tin cans. She said tell me about it, it won't even shut off, as she holds up her keys. It was still dieseling when I got downstairs.
Juanita is her name,
Chaos is her game,
She was not there to tame,
It's perhaps a shame,
But the woman leaves 'em lame.
I watched those videos. He basically figured out what caused the collapse about 3-4 years ago.
