nitrogen & glycol for wine & beer dispensers - limits??
syarn
Silver Member
Philadelphia, Pennsylvania, United States
2009 IBC
1 story; 3100 sf salad restaurant alteration (assembly use group A-2)
adding wine & beer taps;
the wine system uses nitrogen to keep wine fresh;
the beer system looks to use glycol;
I see in IBC definitions that nitrogen is classified as an inert gas & table 307.1 (1) is N/A or no limit quantity...
however what about glycol for the beer system?
it looks like there will be 3 gallons in the system
Propylene glycol, also called 1,2-propanediol, resembles ethylene glycol in its physical properties. Unlike ethylene glycol, however, propylene glycol is not toxic and is used extensively in foods, cosmetics, and oral hygiene products as a solvent, preservative, and moisture-retaining agent. Propylene glycol is manufactured in large amounts from propylene oxide, which is obtained from propylene.
This is some great info on the stuff.
www.osha.gov/dts/chemicalsampling/data/CH_264480.html
Here is a little more information.
http://www.atsdr.cdc.gov/tfacts96.html
ZIG
I take it the glycol is in a closed system????
Do not have the book, but should be no problem
You can ask for the msds for the glycol, to see any hazards
More than likely a class III combustible
syarn said:
2009 IBC1 story; 3100 sf salad restaurant alteration (assembly use group A-2)
Used in chillers all the time as a cooling medium system is not direct expansion there is no change of state from liquid to vapor.
