Robert Ellenberg
The 2008 NEC requires the following: “In Unfinished Basements and Crawl Spaces. Where cable is run at angles with joists in unfinished basements and crawl spaces, it shall be permissible to secure cables not smaller than two 6 AWG or three 8 AWG conductors directly to the lower edges of the joists. Smaller cables shall be run either through bored holes in joists or on running boards.”
This was previously true in unfinished basements but the 2008 edition adds crawlspaces. My question is how do you take wiring from one side of a girder to the other (it is not a dropped girder but the joists butt into it). The code makes no provision for drilling holes in girders (and it shouldn't). Can you tack a small piece of wood on the bottom of the girder (a short section of running board), run your cables parallel to or through holes in the joists on one side of the girder, drop the wire down and tack it to the short section of running board and then continue back up on the other side of the girder?
Would appreciate comments on whether or not you would consider this compliant and/or any other way to meet this provision.
