Reference: 334.12(B)(4) not permitted in a wet or damp location, 300.9 Raceways in Wet Locations Above Grade. Where raceways are installed in wet locations above grade, the interior of these raceways shall be considered to be a wet location. Insulated conductors and cables installed in raceways in wet locations above-grade shall comply with 310.8(C).Caught working without a permit. Even if the plan was to pull the NM through the exterior UG conduit, that is a no no.
For locations below grade, the reference is 300.5(B).300.9 Raceways in Wet Locations Above Grade.
Thank you for that correctionFor locations below grade, the reference is 300.5(B).
Cheers, Wayne
Can you point me towards an example of commercially available NMC cable that is not also listed as UF cable?They should have used NM-C.
There is none manufactured that is straight NMC but some UF has a double listing UF/NMC.Can you point me towards an example of commercially available NMC cable that is not also listed as UF cable?
Cheers, Wayne
