I don't have an older copy, this is from the NC Uniform Building Code '68 with ammendments through 10 Dec '85.
Section 19 Wood Construction- General
(6) Protection Against Decay and Termites:
(a) In areas subject to termite damage, the following locations shall require the use of an approved species and grade of lumber, pressure preservatively treated in accordance with the standards in para (f) or heartwood of Bald Cypress (Tidewater Red), Redwood, and Eastern Red Cedar.
1. Wood joists or the bottom of a wood structural floor when closer than 18" or wood girders when closer than 12" to exposed ground in crawl spaces or unexcavated areas located within the periphery of the building foundation.
2. All sills which rest on concrete or masonry exterior walls and are less than 8" from exposed ground.
3. The ends of wood girders entering exterior concrete or masonry walls which have clearances of less than 1/2" on to, sides, and ends.
4. Wood siding on the exterior of a building having a clearance of less than 6" from the ground.
How had it done when you went back in there? If appropriate, who was the builder, just curious I was around there then.
Out of curiousity I flipped back a few pages, Excavation; depth of excavation of trenches for walls, piers and footings shall be carried below the frost line.
