nealderidder
Sawhorse
I've got a two-story CA office building with two levels of mostly below-grade parking below. The building is type II-B and has no required fire ratings other than the one hour B-S2 separation. The garage is concrete and the office building is steel frame with composite metal deck floors. I've got a seismic joint at the grade level parking deck that runs along side (but outside of) one edge of the building in-line with the second floor above. See attached to make sense of this...
The question is - does the expansion joint need to be fire rated? There is no enclosed "B" space above this joint until you get to the 2FL above, some 14' overhead and even then it's right on the exterior boundary of that wall.
The seismic (I'm using seismic and expansion interchangeably) joint I want to use doesn't come with a fire rated listing. I can get around this by using a fire rated joint filler below the fancy pants seismic cover but I don't want to do that if I don't have to...
So after all that, question remains - does this expansion joint need to be fire rated?
