Hyrax4978
So here is my current puzzle to solve. I have a mezzanine in which we maxed out its size due to travel distances. next to the mezzanine we had an equipment platform the client was going to put an industrial piece of equipment. So it was completely separated from the mezzanine. Now the owner wants to put the equipment elsewhere and make that space accessed by a door from the mezzanine. They want to make it their data closet and have it be a tempered room. its a decent size space, about 90 SF. by adding the door into this new room that was previously just a mechanical platform that didn't have a door to it we are possibly extending the travel distance to far.
There is no clear cut definition i can see if a data closet, or mechanical closet is occupiable. travel distance is clarified in the commentary as from every occupiable point. So if a data closet or mechanical room is not occupiable then i would say the travel distance would stop outside that room.
However the commentary for habitable space says "though other occupiable spaces, such as halls or utility rooms" kind of makes it seem like utility rooms are occupiable. There is also an occupant load for mechanical equipment rooms which also makes it seem like mechanical rooms are occupiable.
It seems like mechanical or electrical rooms should fall outside of the occupiable spaces because they only have people in them during times of repair or renovations.
thank you,
Brian
thank you,
Brian
