Oops Again
There is striping across the driving lane to the entrance, it just changes direction to be parallel to the parking spaces. I didn't have a tape handy to measure the distance between the posts supporting the accessible parking signs, but it might be 32" (I hope!) Maneuvering a wheelchair around the light post would be a challenge.
Sifu, I agree that 32" is less than ideal. But if they can find a way to meet the minimum 32" clear around the post (maybe removing the base moulding?), then I'm assuming it complies with code and ADA, and is approvable.
Though it may not be best practice, sometimes "just barely" = good enough".
Agreed. Fortunately I am not in a position to decide if their remedy will work. I was just there to point out issues, not approve or deny anything. This picture was included as a situation where they reduced the effectiveness of the access aisle. They have issues that may require many of the spaces to be relocated so I o pointed this out as something they should pay attention too if/when they do it.
GO STEELERS!
I recommend striping to limit the exacting workmanship required by ADA and FHAG for sites. That way the accessible routes are defined and designated and everything only has to be perfect within the ADA route.
On your photo below if the property management company can widen the stripped aisles between the cars an individual in a wheelchair should be able to go around the post concrete base as long as there is at least a 36" clear route on one side of the post base. There might be enough room now. You would need to measure diagonally out from the base to see if there is 36" wide passage.
This is the access aisle from the accessible parking spaces to a grocery store near us.
