opening for two rooms to be one
Tyr
north carollina
I am raising the question of how much dividing wall must be removed for two rooms to be treated as one room for purposes of fire egress. This is very relevant in a common setting of basements in ranch style houses.
Picture a common basement with the long axis excavated generally parallel to contour lines of a hillside. The downhill wall is "daylight" and the uphill retaining wall and its wing walls are windowless. Now also picture ththe floor joist and "width" of the house are inevitably perpendicular to the contour lines and a central stairwell serves the downstairs rooms. On one end of the house from a central hallway there is a bedroom on the daylight side and a den fit only for music and TV. This separated hideaway den became much more pleasant with a finished doorway (no door) punched through to the daylight bedroom.
The improved feeling for the buried den awakens the concept of the suite which is combo bedroom and sitting space. All is backward unless the sitting space is on the daylight side and the sleeping area on the quieter retaining wall side.
The wall is 13 feet non load bearing (former open basement pillars and beams) and the doorway is finished with no door. I can easily remove more wall to about 5 feet opening in which case there would remain a section of narrow reachin closet that also encloses one support pillar and a heat duct.
I could also remove the entire closet and and central pillar and duct but dont want to remove more than necessary
The point is the sleeping area should be in the quieter part of the basement and not separated from the daylight portion in a 24 foot wide house and the windows and door serve this unified space..
So what am I asking?
Where is the definition in the code by which a pair of room spaces function as one? Can a bedroom be the full width of a basement with some amount of a peninsula wall? How much opening and how much wall? Is the doorway lacking a door sufficient?
Thanks as a first timer
Tyr
About how old is the house ?
So is the bedroom already existing?
If so was it a bedroom when you bought or built the house??
if so was it inspected by a city building Dept??
About how old is the house ? 60 yrs
As stated the daylight room has been used as a bedroom and the den was a truly dark subterranean place
As stated in the initial post the daylight room has been a bedroom and my questions are about how to coopt the once separate den area into a unified room. I have stated the need to find a definition of what constitutes one room by either a portal constructed with no mounted door or by removing a portion of former dividing wall. The least wall removal preferred.
No . This once once empty basement was divided years ago and I have simply punched a passageway through a curtain wall . I like the functional change and I am willing to remove more wall to achieve a definition of a unified room ... if I can find a definition. I have phrased questions in initial post.
Tyr
Will let others reply
But it sounds like you can remove as much or little of wall as wanted.
For your purposes, I don’t think a definition matters.
Is the city or someone telling you what you want to do is wrong????
My questions were more do you have a legal bedroom.
Existing building code 402.1.1.1 Adjoining spaces
For the purpose of natural lighting, any room is permitted to be considered as a portion of an adjoining room where one-half of the area of the common wall is open and unobstructed and provides an opening of not less than one-tenth of the floor area of the interior room or 25 square feet (2.32 m2), whichever is greater.
Note other additions may vary
Note also that by removing a portion of the wall and increasing the size of the bedroom you are increasing the "taxable" square footage. If you go to sell it later the net square footage advertised may then differ from that shown on the accessor's roles.
Has the rear area remained dry over the years?
Thanks for the interesting definition of adjoining space which defines a threshold for "purpose of natural lighting" As stated in my original post the functionality of the joined spaces is backwards unless the sleeping zone is the more remote space and the sitting zone the more daylight space. But my interest is entirely about the definition of a bedroom being all of a joined space with a fixed passageway (or peninsula wall) for purposes of fire egress.
I have joined these two rooms just because I like their functionality joined and I limited the opening to finished actual 29" by 79" high for an easy penetration of two existing stud cavities. That is about 15.9 sq ft. Its some daylight and easy travel from room to room. The former den area is about 11 by 14 or 154sf, but the definition of 402.1.1.1 Adjoining spaces asks for greater than 25 sf (which I could achieve by taking out more wall).
It would be a pain to remove 1/2 of the separating wall and no point in doing that unless such action does "nail down" the conceptual asset of allowing the former den area to be used as sleeping , which is not forever branded as separate without egress as a bedroom.
Most can agree that standard residential doors do not offer fire protection but only delay in perception of threat. Any permanent open passageway is a path for smoke and smell and all houses would be safer for sleeping with doors removed from their doorways.
I am still looking for an arbitrary code definition of adjoining space for fire purposes (not naturallighting) . My original post should have been titled
"opening for two rooms to become one bedroom".
Such a definition might provoke more revision of the wall to not only be safer and convenient but also code by cookbook. As we know, if you are not in the cookbook whatever you cooked is outside,disowned, and not to be served ... even if it is a move toward benefit and improvement.
Tyr
I do not think bedrooms are required to have doors, someone may correct me on that.
If there is a door it does not have to be rated.
Normally the only fire rated separation required is between an attached garage and the rest of the house.
You can call the open area a setting area, like in the big manisons
My posts on this thread pose specific question about published definition of passageway to cause adjoining rooms to function as one for purposes of fire safety (sensing and exiting within a structure). I find it unusual that fire safety should have to default to a definition of "adjoining" fashioned for the aesthetics of natural lighting. Arbitrarily missing 50% of a separation wall certainly sounds ample but I am searching for any lesser passageway that may exist in the cookbook code. I hope someone can recall or find places in the code for the question I have posed.
Further a few responses to cda intending to promote the topic of this thread:
Probably true but tangential to the question of how much permanent passageway constitutes a joining of adjacent rooms into one so that the joined space has fire egress
True a million times over but such discussion does not lead to a a definition of adjoining (there is no door just finished passageway)
If true this discussion does not relate to making an interior space safer and cheerful by punching some amount of wideopen aperture through an existing wall.
Firecode is not concerned if a wide awake person sits in a closet or closed storage many doors removed from the great out of doors (sort of like the former den) But I am not interested in what I personally call a setting or sleeping area in a joined space....only interested in what the code may define as a threshold of joining two spaces by open passageway through a wall (for purposes of fire egress).... so that all joined space can claim that exterior door and window that already exist
Tyr
This is not a true statement. Even the cheapest of doors can slow or stop a fire from entering a room. Proven plenty of times. As for your situation it could all be considered a bedroom possibly, but the local AHJ will need to assess this so they can see the whole picture and make a decision.
Mike is right. Closing a bedroom door, even a non-rated, non-gasketed door has many times been proven to provide a significant reduction in smoke spread.
So significant is the protection afforded by a closed door that companies such as ceasefiredoorhinge.com have been born.
Tyr
Getting lost on your question
You are talking about an owner house, which parts are not being rented out??
I hate to say codes are more lax in a residential home.
So do you just need the minimum size opening for a passage way, for exiting??
R311.2 Egress door.
Not less than one egress door shall be provided for each dwelling unit. The egress door shall be side-hinged, and shall provide a clear width of not less than 32 inches (813 mm) where measured between the face of the door and the stop, with the door open 90 degrees (1.57 rad). The clear height of the door opening shall be not less than 78 inches (1981 mm) in height measured from the top of the threshold to the bottom of the stop. Other doors shall not be required to comply with these minimum dimensions. Egress doors shall be readily openable from inside the dwelling without the use of a key or special knowledge or effort.
My 2 cents ... you have posted an awkward question, that would have been more clear with a sketch. That happens. But then your subsequent posts are sprinkled with phrases that imply you are bothered by people asking questions that you thought had been made clear in the first post. Lighten up.
one-half of the area ... not less than one-tenth of the floor area
Mark ... trying to understand this. Suppose the back room is 16x16 ft = 256 sf and the wall is 8 ft high. To satisfy the first part, the opening would have to be one half of 8x16 ft = 64 sf. So a 7 ft high opening would have to be 9 ft wide. And to satisfy the second part, the opening would have to 256/10 = 26 sf.
There are two conditions, you need to meet both
1. one-half of the area of the common wall
(how wide is the common wall?) 26 SF /8 Ft = 3ft 3in wide But if the wall is 10 feet you need 5' wide 8' high.
AND
2. an opening of not less than one-tenth of the floor area of the interior room or 25 square feet , whichever is greater.
I haven't read it all but it appears that Tyr is trying to create a bedroom in a basement without an EERO.
Not sure what his real question is???
He says there is already a bedroom there.
The house is old.
He is worried about fire safety
He wants to open a wall some or more?
In the old days, we use to have one room houses, so not sure what the problem is.
