Openings in Open Garages Simplified - IBC 406.502
Educational Summary on Open Garages for Commercial Codes (IBC Section 406.5.2)​
Key Requirements for Natural Ventilation in Open Parking Garages:​
  • Uniformly Distributed Openings:
    • The exterior side of the structure must have uniformly distributed openings on two or more sides.
    • These openings must cover at least 20% of the total perimeter wall area of each tier.
    • The total length of these openings must be no less than 40% of the perimeter of each tier.
  • Interior Walls:
    • Interior walls should also have openings that make up at least 20% of the wall area to ensure adequate ventilation.
  • Exception for Cross Ventilation:
    • If the structure has uniformly distributed openings on two opposite sides, the 40% perimeter opening requirement does not apply.
    • However, the openings must still meet the 20% of the total perimeter wall area requirement.
  • Below Grade Openings:
    • If openings below grade provide the necessary natural ventilation, the exterior horizontal clear space must be one and a half times the depth of the opening.
    • This clear space must extend from the grade down to the lowest required opening.
Importance of Openings and Ventilation:​
  • Safety and Ventilation:
    • Properly distributed exterior wall openings facilitate natural ventilation, aiding in the dissipation of heated gases and enhancing safety.
    • Open parking garages are considered relatively low hazard due to the natural ventilation provided by these openings.
  • Challenges with Below Grade Openings:
    • Openings below grade require careful consideration to ensure sufficient horizontal clear space for adequate air movement.
    • The required clear space increases proportionally with the depth of the openings below the surrounding grade.
Commentary:​
  • Open parking garages must meet specific criteria for natural ventilation to ensure safety and functionality.
  • Uniform distribution of openings is crucial for effective ventilation.
  • Provisions are in place to address the challenges of providing adequate ventilation for openings located below grade.
By adhering to these guidelines, open parking garages can maintain low hazard levels while providing necessary ventilation.
