Outdoor commercial grill
Mr. Inspector
Poconos/eastern PA
There does't seem to be an exception for hoods and exhaust system for an outdoor grill. A restaurant want to grille outsid on a deck. Not sure how to handle this. Anyone have an idea?
It is outdoors
No ceiling or roof???
And health dept will not require any cover??
IMC
101.2 Scope
......within buildings....
Not within a building then it is not within the requirements of the IMC.
Check out definition of "exhaust System"
`12 IMC, Section 303.6 - Outdoor locations:
"Appliances installed in other than indoor locations shall be listed and labeled for outdoor installation."
IMC 2012
301.1 Scope.
This chapter shall govern the approval and installation of all equipment and appliances that comprise parts of the building mechanical systems regulated by this code in accordance with Section 101.2.
The scope is the charging language for each chapter or section. Outdoor cooking equipment that is not part of a building mechanical system is not regulated by the code for hoods and exhaust, Manufactures installation instructions and listing would govern the equipment use, placement and distance to combustibles.
[A] 101.2 Scope.
This code shall regulate the design, installation, maintenance, alteration and inspection of mechanical systems that are permanently installed and utilized to provide control of environmental conditions and related processes within buildings.......
BUILDING. Any structure used or intended for supporting or sheltering any use or occupancy.
STRUCTURE. That which is built or constructed.
Would you call a patio attached to a building with a canopy that completely covers the patio a;;;,
Open on three sides
A Structure and a building???
I am not making an assumption there is a roof over the cooking area since it is "outside"
However if there is, then a hood would be required to protect the structure above.
A quick Google check found many companies listing commercial charcoal grills on their websites here are a couple: http://www.holsteinmfg.com/categories/gas-charcoal-grills http://www.belson.com/Commercial-Barbeque-Grills. I'm not really sure what makes them commercial versus high-end residential but these 2 vendors as well as many others list grills they say are for commercial use. I've been to many outdoor grilling events at country clubs and have never seen a grill under cover at any of those. This is been in several different cities but I'm sure that requirements vary from area to area.
