The following paragraph is from the article at this link https://www.douglaskrantz.com/SCFACPNotSys.html
What is “outside horn/strobe”, where is it located?
The firefighter's outside horn/strobe is powered by utility power. Like a light switch, the flow switch turns on this power, uses wiring to carry this power, and activates the outside horn/strobe.
The firefighter's outside horn/strobe doesn't have a control panel. It doesn't even have anything to detect if the power is turned off or a wire is broken. It's really, though, a complete fire alarm system. (Some people might not consider this as a fire alarm system. However, when heat from a fire is detected by a sprinkler head, water starts to flow, and the outside horn is turned on to announce a fire.)
Outside Horn/Strobe
Another example is the outside horn/strobe that lets the fire department know water is flowing to suppress fires. It also lets the fire department know where to connect hoses for greater ease in fighting the fire.The firefighter's outside horn/strobe is powered by utility power. Like a light switch, the flow switch turns on this power, uses wiring to carry this power, and activates the outside horn/strobe.
