jj1289
During inspections I am seeing more and more doors are being equipped with panic hardware. In most cases it is not required and a very expensive item to install. I have also been on inspections and another inspector (fire and building) would make the statement that panic hardware is required. They make the statement without researching first and I have corrected them for this. Below is an outline on the requirements, excluding some exceptions;
When is panic and fire exit hardware required?
It is required in the following situations:
[BE] PANIC HARDWARE. A door-latching assembly incorporating a device that releases the latch upon the application of a force in the direction of egress travel. See “Fire exit hardware.”
[BF]FIRE EXIT HARDWARE. Panic hardware that is listed for use on fire door assemblies.
The above references are based on the 2024 IBC, 2024 IFC and the 2023 NEC
- Swinging doors in Group H occupancies (1010.2.8)
- Group A room/space with occupant load > 50 (1010.2.8)
- Group E room/space with occupant load > 50 (1010.2.8)
- Refrigeration rooms > 1,000 sf (1010.2.8.1)
- Electrical rooms with equipment rated ≥ 800 amperes when exit access is < 25 ft from equipment (1010.2.8.2, NEC 110.26(C)(3) & 110.33(A)(3))
