Yikes
CBC 1126A.3.2.1 requires 12" strike-side clearance on the push side of a door equipped with a latch and closer.
I have a 3' wide doorway at the bottom of a 4-story exit stairwell, and the width of the space is 44", which is too narrow for the 12" strike side clearance.
I've been told the rationale behind the 12" clearance is to allow a frail person to center their body in front of the door handle to maximize their "leverage" in the push effort to open the door.
Question: would you consider it an acceptable modifcation / equivalent facilitation to install a panic bar in lieu of the 12" strike clearance?
This means a person could just lean into the bar and open it, effectively mitigating the complicating effect of the latch.
