We would like to build a space above our garage, which is attached to our house, and use it as an office. The space will have a bathroom and a small closet for cleaning supplies, but no kitchenette. We will never use it as a bedroom – just as a space where I can work and store stuff.
The space would not be connected to the main house, and the only way to access the space will be stairs (not yet built) inside the garage. There will however, be a number of operable windows in the front and back of the space through which people could easily enter and exit in case of a fire.
The city is telling us that we have to have a means of egress from the space that does not require travel through the garage, per IRC Section R311.1. To do this, they want us to build a wall across the back portion of our garage to create an enclosed hallway from a man door out the back of our garage to the stairs that lead up to the space. We do not want to build this wall, as it will prevent us from parking our car in the garage.
IRC Section R311.1 says: “Dwellings shall be provided with a means of egress in accordance with this section. The means of egress shall provide a continuous and unobstructed path of vertical and horizontal egress travel from all portions of the dwelling to the required egress door without requiring travel through a garage.”
Our question is this: Does the proposed space qualify as a “dwelling” as used in the IRC?
Definitions in the IRC:
Dwelling: Any building that contains one or two dwelling units used, intended, or designed to be built, used, rented, leased, let or hired out to be occupied, or that are occupied for living purposes.
Dwelling unit: A single unit providing complete independent living facilities for one or more persons, including permanent provisions for living, sleeping, eating, cooking and sanitation.
The proposed space will not have permanent provisions for eating and cooking, and it would not be occupied for living purposes. It seems to me then that it would not qualify as a dwelling for purposes of R311.1 and that we should not have to have the requested means of egress that does not go through the garage.
I would very much appreciate anyone’s thoughts on this. Thank you!
