jdfruit said:
tmurrayHow do you get a copy of the Canadian code intent document? Preferably free pdf.
Now I wonder if there could be traction for objective based codes in the US?
http://codes-guides.nrc.ca/IA/10NBC/intentframe.html''>
http://codes-guides.nrc.ca/IA/10NBC/intentframe.html' rel="external nofollow">
Use the tree navigation system on the left hand side of the page. Our acceptable solutions part of the code is called Division B, which is broken into Parts.
Part 3 Fire safety, washroom requirements and accessibility (our version of ADA)
Part 4 Structural
Part 5 Environmental Separations
Part 6 HVAC
Part 7 Plumbing (sends you to National Plumbing Code)
Part 8 Safety at construction and demolition sites
Part 9 Housing and small buildings (includes offices, mercantile and low & medium hazard industrial up to ~6500 square feet & less than 4 stories in height)
For instance the following is the text that I get when I look up the requirement for a smoke alarm on each storey;
Objective OS1 Fire Safety
Attribution [F11-OS1.5]
Intent 1:
To limit the probability that a fire involving a storey will not be detected, which could lead to persons on that storey or on another storey not being promptly notified of the fire, which could lead to delays in the evacuation or movement of persons to a safe place, which could lead to harm to persons.
Intent 2:
To limit the probability that persons in sleeping rooms will not be promptly notified of a fire in other parts of the dwelling unit or within their room, which could lead to delays in the evacuation or movement of persons to a safe place, which could lead to harm to persons.
OS1 in general refers to provisions that are required for fire safety. We get a little more detailed when we look up F11 and OS1.5 together;
F11 refers to the following:
To notify persons, in a timely manner, of the need to take action in an emergency.
OS1.5 refers to the following:
persons being delayed in or impeded from moving to a safe place during a fire emergency.
So, someone could conceivably come up with a way to notify everyone there is a fire and make sure they are able to exit the building in a timely manner and prove that their method meets or exceeds the same level of safety that is achieved by the prescriptive code, it is acceptable as an alternative solution.
We have this for every single sentence in our code. I should note that this is not a consensus based code. Anyone can propose changes, they are reviewed for technical feasibility, and sent before a joint committee of industry experts, builders, and code officials for discussion. Then, the proposed code is released for a public review for comments. Once complete, the code is finalized and published during the next cycle. The main difference is the requirements for technical feasibility. Sprinklers in one and two family dwellings failed to meet this requirement (cost per life saved was too high).
