JohnM
I will be installing the automatic switch box for a new generator. It will be mounted outside, near an outside corner of the house. How close to the corner can it be mounted?
Is that local requirement?Was finally able to get an electrician out to the house. Decided to use the original service drop and meter socket. The rules have changed and installing a new sock requires 12' from the ground for the head. That would require guy wires and shimming and...
So you're ok having the head less than 12 ft high?a new sock requires 12' from the ground for the head.
